Warning message
failover on two different links
Answered Question
Nov 28th, 2006
how can i apply the failover concept, if i have customer connected to a 3750 switch and two uplinks that are pointing to two different networks. the customer gateway points to the first uplink, how can the other uplink send the customer's traffic to the internet if the first uplink failed?
Correct Answer by amit-singh about 10 years 8 months ago
If you have 3 of these 3750's. You can have a hub and spoke topology. Like this
Use 3750 A for client connectivity
Use 3750 B for say ISP 1 with one of the host connected to it.
use 3750 C for ISP 2 and have a trunk between 3750B and 3750C with the SVI's configured.
So 3750 A is connected to 3750B and 3750C on routed port.
On 3750 a Put you client on vlan1 and create a SVI for it. Put the ports connected to 3750B and 3750 C on a routed port
On 3750A
Conf t
ip routing
int vlan 1
ip address 1.1.1.1 255.255.255.0
no shut
int fa 0/1
no switchport
ip address 2.2.2.1 255.255.255.0
no sh
int fa 0/2
no switchport
ip address 3.3.3.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 2.2.2.2
ip route 0.0.0.0 0.0.0.0 3.3.3.2 200
On 3750 B :->
Conf t
ip routing
int vlan 2c--> Connect your PC on Vlan2
ip address 11.11.11.1 255.255.255.0
no shut
int fa 0/1
no switchport
ip address 2.2.2.2 255.255.255.0
no sh
int fa 0/2 -> trunk to 3750C
switchport encapsulation do1tq
switchport mode trunk
ip route 1.1.1.0 255.255.255.0 2.2.2.1
ip route 1.1.1.0 255.255.255.0 11.11.11.2
On 3750 C :->
Conf t
ip routing
int vlan 2
ip address 11.11.11.2 255.255.255.0
no shut
int fa 0/1
no switchport
ip address 3.3.3.2 255.255.255.0
no sh
int fa 0/2 -> trunk to 3750B
ip route 1.1.1.0 255.255.255.0 3.3.3.1
ip route 1.1.1.0 255.255.255.0 11.11.11.1
Once that is done and you are pinging from the host on 3750 A to host on 3750B, go ahead and disconnect the cable between 3750A and 3750B, the traffic should pass through 3750C.
HTH,
-amit singh
Overall Rating: 4.5 (2 ratings)
ankbhasi Tue, 11/28/2006 - 00:24
  • Cisco Employee,
Hi Sawsan,
When you say 2 different networks you mean 2 different subnets? The 2 Uplinks are connected to different subnets on 2 different routers?
Ankur
sawsan.mohamed Tue, 11/28/2006 - 00:41
Hi ankbhasi,
yes, for example, the first uplink (213.42.87.0), the second uplink (80.17.60.0)on two different routers
ankbhasi Tue, 11/28/2006 - 00:56
  • Cisco Employee,
Hi Sawsan,
Instaead of defining a gateway can we have 2 static routes pointing to 2 different address with second one having higher admin distance.
Something like this
ip route 0.0.0.0 0.0.0.0 200
ip route 0.0.0.0 0.0.0.0 220
In this case when first link goes down the second static route will take the action.
Ankur
sawsan.mohamed Tue, 11/28/2006 - 01:34
how can I test this concept and prove it, if i'm having 3 of Cisco 3750?
ankbhasi Tue, 11/28/2006 - 01:51
  • Cisco Employee,
Hi Swasan,
If this 3750 working as a complete layer 2 switch? or you are using it as a layer 3 edge for customer?
Ankur
Correct Answer
amit-singh Tue, 11/28/2006 - 01:53
  • Blue, 1500 points or more
On 3750A
Conf t
ip routing
int vlan 1
no shut
int fa 0/1
no switchport
no sh
int fa 0/2
no switchport
On 3750 B :->
Conf t
ip routing
no shut
int fa 0/1
no switchport
no sh
On 3750 C :->
Conf t
ip routing
int vlan 2
no shut
int fa 0/1
no switchport
no sh
HTH,
-amit singh
sawsan.mohamed Tue, 11/28/2006 - 03:22
thanks for both of you,
and thanks amit for the configuration..i will try to configure it and see the results.
bond12345 Tue, 11/28/2006 - 03:28
If you have two links connecting on the same router,then the solution to send the traffic to other link when one fails is to put a static route with some higher metric.e.g
ip route 0.0.0.0 0.0.0.0 x.x.x.x 200
where x.x.x.x is the next hop ip address.
