What is the meaning of RPC Message Typ 3 class 39
Nov 28th, 2006
I have an 3750er Catalyst. This switch sends me an Error Message:Platform_RPC-3-MSG_Throttled: RPC Typ 3 Class 39 . What RPC Message is Throttled (RPC Typ 3 Class 39.
Thanx for your help.
amit-singh Tue, 11/28/2006 - 00:56
  • Blue, 1500 points or more
Let us know what all messages you are getting. Is that the only log message that you have.
Can you paste the switch configuration.
HTH,
-amit singh
mtraettner Tue, 11/28/2006 - 03:57
Thats the only Message:
Sorry but by the customer, is not allowed to paste the Config.
Thank you
amit-singh Tue, 11/28/2006 - 04:05
I have just come across a bug for the same. Let us know if that can help.
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCeg57839
Here is the explanation:
Symptom:
The following message is displayed on a Catalyst 3750 or 3560 switch:
%PLATFORM_RPC-3-MSG_THROTTLED: RPC Msg Dropped by throttle mechanism: type 3, class 39, max_msg 4, total throttled 16
Condition:
The user is trying to create a routed interface when snmp-server ifindex persist
is configured.
Workaround:
Remove the command snmp-server ifindex persist from the configuration.
Additional Information:
The command snmp-server ifindex persist is not supported on the Catalyst 3750, 3560, and 2970
HTH,Please rate if it does.
-amit singh
