Warning message
Why 67 series modules not supported by Sup32 on the 6500?
b.orth Tue, 11/28/2006 - 06:05
Not that I'm aware of.
My understanding is the 67 cards are "fabric" enabled, meant to be used with Sup 720's. HTH.
amit-singh Tue, 11/28/2006 - 09:36
  • Blue, 1500 points or more
67xx cards are only supported with Sup720 because the way they connect to the backplane. They have dual 20Gig connections to the backplane though the SFM 720.
Sup32 doesnot have a SFM to work with them and doesnot provide those connections for 67xx cards to connect to the fabric channel.
HTH,Please rate if it does.
-amit singh
