forcing traffic to a particular url
Answered Question
Nov 28th, 2006
Hello
I would like to be able to force traffic destined for this url http://test.eircom.ie to go to service A and traffic for http://test.eircom.ie/ws to go to service B.
How might I do this?
Donagh
Correct Answer by Gilles Dufour about 10 years 8 months ago
Here you go:
owner MyCompany
content WS
vip x.x.x.x
proto tcp
port 80
url "/ws/*"
add service service_B
active
content Any
vip x.x.x.x
proto tcp
port 80
url "/*"
add service service_A
active
Overall Rating: 5 (1 ratings)
Gilles Dufour Tue, 11/28/2006 - 08:45
  • Cisco Employee,
Donagh,
could you please specify what hardware you are using.
You will need a L7 rule to match on the url, but the config is different depending on the hardware.
Gilles.
donaghq_2 Tue, 11/28/2006 - 09:02
Hi Gilles
Thanks for your reply.
I am using a CSS11503.
Donagh
Correct Answer
Gilles Dufour Wed, 11/29/2006 - 02:36
  • Cisco Employee,
Here you go:
owner MyCompany
content WS
vip x.x.x.x
proto tcp
port 80
url "/ws/*"
active
content Any
vip x.x.x.x
proto tcp
port 80
url "/*"
active
donaghq_2 Fri, 12/29/2006 - 09:04
Hi Gilles
I have tried to implement this but I cannot get it to work. The big difference is that I am trying to do this for SSL traffic. Here is my config
content TEST-ssl
vip address 10.40.21.26
application ssl
add service tst01-SSL-2443
add service tst01-ssl-2444
advanced-balance sticky-srcip
protocol tcp
port 443
url "/*"
active
content TEST-ssl-01
add service tst01-SSL-2445
add service tst01-SSL-2446
application ssl
protocol tcp
port 443
url "/WS/*"
active
Traffic destined for https://test.eircom.ie/go gets transferred to ports 2445 and 2446. Traffic destined for https://test.eircom.ie/WS does not work and returns a "page cannot be displayed" error.
Traffic for "/WS/*" is being delivered to the webserver by means of a POST using a service called SOAP over HTTP. Perhaps that makes a difference to the operation?
Donagh
Gilles Dufour Sun, 12/31/2006 - 08:05
  • Cisco Employee,
Donagh,
the big difference with ssl is that traffic is encrypted so nobody (including the CSS) can see the data. Therefore the CSS does not see the url and it fails to match a content rule.
The first rule is ok because the url is match any.
You need an ssl module to do this.
Gilles.
