Warning message
How to rebuild unity primary server?
Nov 28th, 2006
Currenlty I have only functional failover server. Primary server has failed.
Is there a document available in Cisco. to rebuild the primary server?
This is a unified messaging set-up with unity version 4.0.5
Tommer Catlin Wed, 11/29/2006 - 08:44
  • Green, 3000 points or more
You should be able to restore from backup. If you do not have a DIRT backup of the primary, you might have to call TAC on this. The Failover Wizard has all the settings in place such as server name, directories, IP addresses, etc of your primary. If your primary comes back and it does not match what it has in it's database, it will never be a primary server.
Your best bet is DIRT restore for the primary. But check out this link for more information:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_white_paper09186a00801f4ba7.shtml#wp1187378
cheers
