How to configure IPSEC on PIX?
m.sir Wed, 11/29/2006 - 03:44
  • Gold, 750 points or more
For VPN client connection you need configure Easy VPN server (sometimes called remote access VPN) on PIX
Following link could be helpful
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_configuration_example09186a00801e71c0.shtml
Its for version 6.x but also contains guide for VPN client
If you are using version 7.x check following link
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_70/config/vpnrmote.htm
M.
hope that helps rate if it does
