Warning message
1802W router (wireless functions yet NO internet or network function)
Nov 29th, 2006
Dear Cisco Users,
Recently we purchased a 1802W integrated services router to upgrade our current infrastructure. However, I am having some problems with my internet connection for my wireless associated clients.
Wireless clients authenticate properly to the router. However, no network functionality or internet connection can be established. Wired connected clients do have internet.
Could someone please give me some pointers. Is it a bridging problem? The wireless application is terribly slow and getting at my nerves.
Tommie
---- config ---
interface Dot11Radio0
no ip address
encryption vlan 1 key 1 size 128bit xxx transmit-key
encryption vlan 1 mode wep mandatory
ssid K3g
vlan 1
authentication open
guest-mode
infrastructure-ssid optional
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 port-protected
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
ssid K3a
vlan 1
authentication open
guest-mode
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface Dot11Radio1.1
no cdp enable
bridge-group 1
Stephen Rodriguez Wed, 11/29/2006 - 12:06
  • Purple, 4500 points or more
Well without seeing the whole config, I can only guess. Do you have a BVI 1 interface? If so does it have the IP address or is it still on the VLAN 1 interface? Is VLAN 1 a member of Bridge-group 1? Also, if you only have the one VLAN, you do not need to use subinterfaces on the Dot11Radio interfaces.
If moving the IP address and all subsequent commands, ie nat inside etc, does not fix the issue, please post a full config from the AP so we can see the whole picture.
john.preves Wed, 11/29/2006 - 13:30
  • Silver, 250 points or more
Also what version of code are you running?
SSID's need to be in the Global config on some releases not just under the radio interface...
Sh run and sh ver please...
Stephen Rodriguez Thu, 11/30/2006 - 10:20
John,
The code that runs on the ISR is similar to 12.3(2) where you configure the SSID under the radio interface and not with the dot11 ssid commands.
john.preves Fri, 12/01/2006 - 09:01
Thanks for the info...Trying to catch up..
