11-30-2006 10:36 AM - edited 03-11-2019 02:03 AM
hi guys, i got some prob in ASA plz help me out,,
pc1-----------ASA----------pc2
outside inside
now see nat is disabled and i have given an accesslist to allow pc1
to ping pc2. till here it is working fine. now suppose i have issued a
continuous ping from pc1 to pc 2 it goes well but meantime from CLI i removed the access list ! but the ping is still going !!!! if i stop it n
then issue ping again it is not going as expected, but my question is
why didnt it stopped when i removed the accesslist ???
heres my own guess, because the connection was formed already in ASA
stateful table so it was allowing it to go, so is it possible that if i
changed or modify an access list it takes the action immediately ? is
there any command for that ??? becoz i m having a lot of problem in testing
time
based acls they r simply not at all working with ASA, i m using 7.0 ios
so
any help plz ???
12-02-2006 07:57 PM
You're right. It will still pinging because the connection table for the existing ping session is still active. It will only gone if you manually stop the ping or issue 'cle xlate' command.
Use the 'clear xlate' everytime you want to clear the connection
AK
12-03-2006 03:42 AM
but dont u think this is inconvenient ?? like if there are 2 outside users connected to my webserver n i want to block 1 of them so i designed an acl but if i clear xlate then both of the connections will be reset !!! is there any other way
12-03-2006 05:35 AM
Another way is to use "clear local-host
FWALL#clear local-host 10.1.1.15
This will clear the network state of a local host stops all network connections and xlates that are associated ONLY with the local hosts.
AK
