Warning message
T1 PRI TEI_ASSIGNED
Nov 30th, 2006
  • Bronze, 100 points or more
I am having some problems getting a router and a pbx to establish layer 2 connectivity. My t1 and D channel config is as follows
controller T1 1/1
framing esf
linecode b8zs
pri-group timeslots 1-12,24
interface Serial1/1:23
no ip address
no logging event link-status
isdn switch-type primary-4ess
isdn incoming-voice voice
no cdp enable
Whenever i do a sh isdn stat the layer two status says TEI_ASSIGNED and whenever i do a debug isdn q921 i get
ISDN Se1/1:23 Q921: User TX -> SABMEp sapi=0 tei=0
ISDN Se1/1:23 Q921: User RX <- BAD FRAME(0x00017F)
What could be the problem is it the router or the pbx, help would be greatly appreciated. Thanks.
Erick Bergquist Thu, 11/30/2006 - 15:23
  • Silver, 250 points or more
Do you have the right ISDN switch type? Did you try toggling between the different types?
Which side is network and user side? By default router is user side.
What type of PBX?
kwillacey Thu, 11/30/2006 - 18:35
The router is network side and providing the clocking, the pbx engineer had a hard time finding the switch type but its using primary-4ess. Its a mitel pbx.
