ASA Multiple Context NAT problem
Dec 3rd, 2006
Dear all,
I am having problem when configuring NAT in multiple context. Since the 2 context are sharing the same subnet in some interfaces, I use the same nat/global command in both contexts. But turns out reporting 'the same global ip is used by another context'. Is there any clue on this?
Thanks in advance.
Br,
Sam
sebastan_bach Mon, 12/04/2006 - 13:16
hi sam u would get this error when u are using a shared interface in multiple context mode. make sure to use different global addresses when using a shared interface. when using seperate interfaces in context u will not face this problem.
see ya
regards
sebastan
