12-04-2006 09:41 AM - edited 03-17-2019 08:52 PM
Does anyone have a sample SCCP configuration for a VG224 Gateway? I have the device set up in CallManager, but I know my configuration on the Gateway is probably not right. Can anyone help? Thanks
12-08-2006 10:44 AM
01-04-2007 01:23 AM
Hereby I send you a VG224, SCCP configuration with fallback to a SRST router when the CallManagers are unavailible.
VG224#sh run
Building configuration...
Current configuration : 3797 bytes
version 12.4
no service pad
service password-encryption
hostname VG224
boot-start-marker
boot system slot0:vg224-i6s-mz.124-9.T.bin
boot-end-marker
enable password cisco
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa authentication ppp default local
aaa authorization exec default local
aaa session-id common
resource policy
clock timezone gmt 1
stcapp ccm-group 1
stcapp
stcapp feature access-code
voice-card 0
voice service voip
modem passthrough nse codec g711ulaw
application
global
service alternate Default
username Administrator privilege 15 secret cisco
interface FastEthernet0/0
ip address 10.3.0.2 255.255.254.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 10.3.1.254
ip route 192.168.200.0 255.255.255.0 10.3.1.250
no ip http server
control-plane
voice-port 2/0
compand-type a-law
cptone NL
voice-port 2/1
compand-type a-law
cptone NL
voice-port 2/23
compand-type a-law
cptone NL
sccp local FastEthernet0/0
sccp ccm 144.16.213.118 identifier 2 priority 2 version 4.1
sccp ccm 144.16.213.134 identifier 3 priority 3 version 4.1
sccp ccm 10.3.0.1 identifier 4
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 2 priority 2
associate ccm 3 priority 3
associate ccm 4 priority 4
switchback method graceful
dial-peer voice 200 pots
service stcapp
fax rate disable
port 2/0
dial-peer voice 201 pots
service stcapp
fax rate disable
port 2/1
dial-peer voice 202 pots
service stcapp
fax rate disable
port 2/2
dial-peer voice 203 pots
service stcapp
fax rate disable
port 2/3
dial-peer voice 204 pots
service stcapp
fax rate disable
port 2/4
dial-peer voice 205 pots
service stcapp
fax rate disable
port 2/5
dial-peer voice 206 pots
service stcapp
fax rate disable
port 2/6
dial-peer voice 207 pots
service stcapp
fax rate disable
port 2/7
dial-peer voice 208 pots
service stcapp
fax rate disable
port 2/8
dial-peer voice 209 pots
service stcapp
fax rate disable
port 2/9
dial-peer voice 210 pots
service stcapp
fax rate disable
port 2/10
dial-peer voice 211 pots
service stcapp
fax rate disable
port 2/11
line con 0
line aux 0
line vty 0 4
end
01-10-2007 08:07 PM
Hi,can you guide me by providing any link mentioning how to configure VG224 and see it on on CCM 4.1.3 ...AS I never worked on it before
Fawad
