PETER NEGUS Tue, 12/05/2006 - 10:17
The best way to do this is to put the following lines in your router
mgcp
ccm-manager config server
ccm-manager config
The ccm will then automatically download the config that you insert in the gateway config page.
You may want to disable music on hold as this can chew up a lot of bandwidth.
