DHCP Address Reservation
vincent-n
Level 3
Level 3
I was wondering whether this config would work or not. I have a printer that needs to be configured with a static IP address and it can't be done on the printer itself but instead via DHCP address reservation. This is what I configured on my router which acts as a DHCP server for a small office.
ip dhcp pool Auckland-Main
import all
network 10.210.3.0 255.255.255.128
domain-name mediamonitors.com.au
dns-server 10.209.3.7 10.95.3.10
default-router 10.210.3.1
ip dhcp pool Auckland-Static
import all
host 10.210.3.32 /25
client-identifier xxxx.xxxx.xxxx
client-name ABCD
What happpen is when the printer is turned on, it will pickup a DHCP address from the Auckland-Main pool but when I do "show ip dhcp bind", the router actually shows two IP addresses. One is from the Auckland-Main and the other is from Auckland-Static.
Thanks in advance for your help.
sachinraja
Level 9
Level 9
Vincent..
instead of leaving it to DHCP (which will change your printers IP sometimes), u can create static binding on the dhcp server (router) to make the IP address of the printer constant at all times.. i think this is the only way to go about this, unless u can manually configure the static IP....
use this URL for reference:
http://cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a008027fa7c.html
Hope this helps.. all the best.. rate replies if found useful..
Raj
sachinraja
Level 9
Level 9
Vincent..
Raj
