spremkumar Tue, 12/05/2006 - 22:52
  • Red, 2250 points or more
Hi Mahendra
Can you post the full command which you wanna know about ?
regds
mahendraoli Wed, 12/06/2006 - 00:13
Hi Prem,
an example of the config is:
class-map match-all VoiceControl
match ip dscp cs5
class-map match-all VoiceTraffic
match ip dscp ef
rgds,
Mahendra
spremkumar Wed, 12/06/2006 - 00:48
Hi Mahendra
In addition to Mark's comments we use different parameters to mark & classify the traffic.
In the config which you have posted basically classifies the traffic with dscp value marked as EF - Expediate Forwarding.
This is very much equivalent to IP Precedence value 5.
We mostly use either ip precedence or dscp values to mark the voice traffic.
When compared to IP Precedence in DSCP you have more bits rather more options so that we can give required priority or guarantee to different traffic patterns.
regds
mahendraoli Wed, 12/06/2006 - 13:18
Hello Prem & mark,
That helps. Thanks heaps.
rgds,
Mahendra
