Warning message
Problem setting up both internal and external (NT Domain) authent. servers
I have setup 2 different user groups, one uses internal and the other uses external (NT Domain) authentication. However, only one group will work at any given time. More specifically, if I position Internal on the top of the autentication server list, then users in the group that uses internal authentication can connection to the VPN device. However, in this setup none of my users in the NT Domain authentication group can connect. On the other hand, if I put NT Domain on the top of the authentication list, then users can connect using NT Domain server but not users using Internal authentication.
Seems like only the 1st authentication server in the list is active?
BTW, I have the Cisco Concentrator 3005.
Thank you in advance.
