12-06-2006 12:53 AM - edited 03-11-2019 02:04 AM
I planed to upgrade the ASA5520, 512 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 64MB which met the minimum requirement to upgrade it, I installed the image asa721-k8.bin successfully but once I issued the command (boot system flash:/asa721-k8.bin) I got the error below :
INFO: Converting flash:/asa721-k8.bin to disk0:/asa721-k8.bin
ERROR: Unable to set this url, a maximum of 4 urls may be configured
Then, I installed the image asa722-k8.bin and again once I issued the boot command I got a different error:
INFO: Converting flash:/asa722-k8.bin to disk0:/asa722-k8.bin
ERROR: Unable to set this url, it has already been set Remove the first instance before adding this one.
Kindly advice what is the issue!!
12-06-2006 07:08 AM
The process on the 525 was.
1. Delete ASDM to make space for the new image.
2. TFTP the new firmware into flash.
3. Remove the boot system flash:/
4. Add the boot system flash:/
5. Confirm with "show run | include boot"
6. Save config and reboot.
7. Delete flash:/old
8. TFTP new ASDM.
9. Remove the boot system flash:/
10. Add the boot system flash:/
11. Remove the asdm image flash:/
12. Add the asdm image flash:/
13. Save config and reload.
12-12-2006 09:43 AM
Issue the following command to remove the first instance:
no boot system flash:/
write mem
After saving, issue the command:
This will take care of your problem.
cheers
08-27-2015 04:59 PM
Thanks this resolved my problem.
