Warning message
12.2(18)SXF5 no VLAN present in Config
Answered Question
Dec 6th, 2006
Good Morning,
We use WS-C6513 Sup720 with IOS release 12.2(18)SXF5.
Since we migrated no VLAN's (exept interface VLan's) are shown in running-config.
They are present and can be configured (e.g. named), but they don't show up in a show running-config command.
Is it a bug, or a feature?
Correct Answer by r.sharafi about 10 years 8 months ago
Usually changing the VTP mode to "transparent" makes your vlans and vtp config visible in the running-config.
Hope it helps!
Ramin
Overall Rating: 5 (1 ratings)
ankbhasi Wed, 12/06/2006 - 06:24
  • Cisco Employee,
Hi Sebastian,
Can you confirm if you see all vlans in "sh vlan" command?
Also can you confirm how you created those vlans?Is it via going to vlan database mode or via global config mode?
Ankur
sebastian.wiegand Wed, 12/06/2006 - 06:33
Hi Ankur,
yes i can confirm, that all vlans show up (even with their configured ASCII-Names) in a "sh vlan" command.
I created them via config mode. After i found out, about the issue i tried to assign some vlans via vl database, but it seem that this database is now an undocumented feature.
"c6513xyz#vlan ?
% Unrecognized command
c6513xyz#vlan
But if u issue the command "vl dat" see this
c6513xyz#vlan dat
% Warning: It is recommended to configure VLAN from config mode,
as VLAN database mode is being deprecated. Please consult user
documentation for configuring VTP/VLAN in config mode.
c6513xyz(vlan)#?
VLAN database editing buffer manipulation commands:
c6513xyz(vlan)#
regards,
Sebastian
Correct Answer
r.sharafi Wed, 12/06/2006 - 08:37
Hope it helps!
Ramin
sebastian.wiegand Wed, 12/06/2006 - 08:48
hi Ramin,
thx...
It's an explanation, but no real solution...
I want my VLAN's appear even if I'm in VTP server mode.
glen.grant Wed, 12/06/2006 - 08:54
  • Purple, 4500 points or more
That is the answer and there is not a solution around it .
