Warning message
VPN Automatically Disconnection in Aggressive Mode
Dec 6th, 2006
Hi All,
Currently i am facing trouble in maintaining the VPN connection.
This VPN is in Aggressive Mode ( PIX to PIX Dynamic-to-Static IPSec with NAT)
Now problem is that VPN connection disconnected when it goes Idle.
We are using this VPN for the voice traffic only.
Now i have two concern while using this VPN for traffic.
1VPN Lifetime 86400 sec ( on Bothe Firewalls)
Currently VPN timed out before 86400 sec , i d,nt know why ?
2. Vpn only established when we start session from the Dynamic IP address Firewall ( remote or client firewall) in this case Central PIX is 515E and Client/remote firewall is PIX 501.
Could you please help me in getting out of this trouble.
ivillegas Tue, 12/12/2006 - 15:13
  • Silver, 250 points or more
Check the DHCP lease time configuration in the central site PIX
bhatti.imran Wed, 12/13/2006 - 20:19
Thanks for reply
Actually No Dhcp involved in this case.
This line is used for VOIP calls only so some times it remains idle particularly on weekends.
So currently we can start VPN session from PIX 501 only but VPN session drops before after some time like 3 hrs 2 hrs etc.
We also want to start the session from PIX 501 side but in this mode i think not possible so I want to have a permanent VPN seesion.
Please any one help me.
Below are the configuration of both side PIX
PiX 515E as a central PIX. ( Ver 7.0)
access-list 101 extended permit ip 172.16.73.0 255.255.255.0 192.168.40.0 255.25
5.255.0
access-list 101 extended permit ip 172.16.73.0 255.255.255.0 172.16.1.0 255.255.
255.0
nat (inside) 0 access-list 101
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map cisco 1 set transform-set myset
crypto map dyn-map 20 ipsec-isakmp dynamic cisco
crypto map dyn-map interface outside
crypto map dynamic-map 1 set security-association lifetime seconds 2147483647
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 2147483647
tunnel-group DefaultL2LGroup type ipsec-l2l
tunnel-group DefaultL2LGroup ipsec-attributes
isakmp keepalive threshold 60 retry 5
tunnel-group DefaultRAGroup type ipsec-ra
tunnel-group DefaultRAGroup general-attributes
authentication-server-group none
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
PIX 501 with Dynamic Global IP ( Ver 6.3)
access-list 101 permit ip 172.16.1.0 255.255.255.0 172.16.73.0 255.255.255.0
access-list 101 permit ip 192.168.40.0 255.255.255.0 172.16.73.0 255.255.255.0
sysopt connection permit-ipsec
crypto map newmap 10 ipsec-isakmp
crypto map newmap 10 match address 101
crypto map newmap 10 set peer 83.136.10.162
crypto map newmap 10 set transform-set myset
crypto map newmap 10 set security-association lifetime seconds 86400 kilobytes 4
608000
crypto map newmap interface outside
isakmp key ******** address 10.10.10.1 netmask 255.255.255.255
isakmp log 2000
isakmp policy 10 lifetime 86400
