CUE Direction for Menu option
Dec 7th, 2006
I am trying to add a menu option on a Unity Express to Perss 4 and be pointed to an end-user w/ the extension of 1515?The Auto Attendant is already configured, just need to re-point the menu option 4 to a different extension?Looking for some direction?..Thanks in Advance!!
Markus Schneider Thu, 12/07/2006 - 10:22
  • Cisco Employee,
canowlin Thu, 12/07/2006 - 11:32
Can you tell accomplish the task below?
I'm getting JTAPI Loging Failed Error while
determining CCM version -1
CUCM is 4.2(3)
CUE is 2.3(2)
Another forum user explained this would solve my issue?
http:///CCMPluginsServer/CiscoJTAPIClient.exe on port 80. IIS in the CallManager is configured to "require SSL" in the CCMPluginsServer directory. After disabling that requirement in IIS, the CUE setup was able to continue.
