DHCP segmentation
Dec 7th, 2006
Let's say I have the segment 172.25.96.0/24 for a Lan.
I have two routers(1711) in this lan using hsrp and 1 virtual router for the gateway.
How can I separate the segment in my dhcp configuration on both routers in order to have ip resolution when one router is down.
Thank you for your help.
Richard Burts Thu, 12/07/2006 - 12:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You have posted the same question in the WAN Routing and Switching forum where I have provided an answer. I suggest that we consolidate the discussion in that forum.
Rick
