Warning message
IOS conditional searches
Dec 8th, 2006
Does anyone know how to search command output based on more than one condition? eg. sh ip route | inc 10.10. | exc ATM ? Of course the eg. doesn't work. Just need to know how to issue conditional searches. Can regexp be used?
Overall Rating: 2 (2 ratings)
Jon Marshall Fri, 12/08/2006 - 02:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Obviously it depends on your IOS to some extent. The main problem seems to be that there is not negation character for a string in the Cisco regular expressions on the IOS (you can negate a single character but that is not much use here) so it is diffcult to say include and then exclude in a regular expression.
The best i seem to be able to do is something like the following:-
DC-BBP-F00-DS1#sh ip ro | include 10.231.198
C 10.231.198.0/25 is directly connected, Vlan61
C 10.231.198.224/28 is directly connected, Vlan70
C 10.231.198.240/28 is directly connected, Vlan71
To exclude Vlan61 from the output you would need to list all the other interfaces ie.
10.231.198.*(Vlan70|Vlan71).*
Maybe someone can do better :-)
