Warning message
Multiple LAP types and VCI strings
Answered Question
Dec 8th, 2006
I'm installing a WLC with 1232AG & 1240AG access points and i would like to know if it's possible to configure 2 different VCI strings for the same DHCP scope, or should I have a scope for each LAP type with the corresponding VCI string?
Thanks for the help
Correct Answer by ankbhasi about 10 years 8 months ago
Hi Friend,
You can have different VCI strings for same DHCP scopes. There are different models of LWAPP AP which use different VCI strings and all the APs can be in same DHCP scope.
Ankur
*Pls rate helpfull post
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Fri, 12/08/2006 - 09:05
  • Cisco Employee,
Hi Friend,
Ankur
l.goncalves Fri, 12/08/2006 - 09:08
Hi Ankur,
Thanks a lot for the quick reply, I can now go on with my installation.
Have a nice week-end!
Luis
