isdn problems
Dec 11th, 2006
Hi all, Is it possible that an isdn line can be set to only be allowed to call one way ? I have a router where it raises the line one way, but when I try to make a call from the other side, it does not work ?
hope you can help
cheers
Carl
Overall Rating: 4 (1 ratings)
spremkumar Mon, 12/11/2006 - 03:36
  • Red, 2250 points or more
Hi Carl
Are you trying to configure dial out and block dial in or the other way around ?
can you throw more clarity on the same ?
regds
spremkumar Mon, 12/11/2006 - 03:54
Hi Carl
You can do it both the ways. But make sure you have different profiles created for dial in and dial out and also make sure that both your isdn channels are used for dial out when you are trying for dial in.
regds
carl_townshend Mon, 12/11/2006 - 08:37
Hi there, I have got the logs of the router and it is coming up with "call rejected - unbindable, and an error 0x8095-call rejected, can anyone help me with this ?
thanks
Carl
