MFT-T1/E1 example config (voice and data on a single port)
Dec 11th, 2006
I'm looking for an example config where you have a T1 circuit terminating on a VWIC2-MFT-T1 card, 6 channels will be for Voice and the remaning 18 will be for data. This is a CME router so the voice channels will terminate internally.
sgossen Tue, 12/12/2006 - 17:54
Never done one, but I assume it would be something like the following:
Controller T1 0/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-6 type e&m-wink-start
channel-group 0 timeslots 7-24 speed 64 (may need to be "channel-group 1" - not sure?!?)
interface Serial0/1:0
yadda yadda yadda
voice-port 0/0:0
yadda yadda yadda
Good luck,
Scot
sgossen Tue, 12/12/2006 - 17:56
NOTE: Sorry, should show up as:
interface Serial0/0:0
(not 1/0:0)
(typo)
-Scot
jrhofman Wed, 12/13/2006 - 06:39
Thanks for the reply.
Here's what we came up with. It's going in today so we'll see how it works.
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 1 timeslots 13-24
ds0-group 2 timeslots 1-6 type e&m-wink-start
interface Serial0/0/0:1
ip address 157.130.244.226 255.255.255.252
voice-port 0/0/0:2
output attenuation 3
echo-cancel coverage 32
no comfort-noise
dial-peer voice 101 pots
preference 1
destination-pattern 9.T
port 0/0/0:2
dial-peer voice 911 pots
destination-pattern 911
port 0/0/0:2
forward-digits 3
dial-peer voice 9911 pots
destination-pattern 9911
port 0/0/0:2
forward-digits 3
sgossen Wed, 12/13/2006 - 11:44
Depending on what/who you are connecting to, don't forget to check clocking.
I did a similar config connecting to AT&T (at the time SBC) but with ours, timeslots 1-12 were fxo-loop-start and timeslots 13-18 were e&m-wink-start. (both were voice)
Good luck,
-Scot
