Warning message
basic internet config for t1 incoming wan
Dec 11th, 2006
what would be a basic internet config on a t1 wic w/ a public ip and two fast ethernet ports? 1841 router. i'm trying to write up a checklist of everthing the config should accommodate so i don't leave anything out.
sachinraja Mon, 12/11/2006 - 14:53
  • Red, 2250 points or more
hello johnny,
sample config of a T1 is as below:
Interface serial 0/0
service-module t1 clock source internal
service-module t1 timeslots 1-24 speed 64
service-module t1 framing esf
service-module t1 linecode b8zs
ip address 10.1.1.1 255.255.255.0
encapsulation ppp
fair-que
no shut
make sure the framing and linecode are configured right. check this with the ISP... if your LAN is on a private range, you also might need to do a NAT/PAT over the T1 interface.. for NAT examples refer to the CCO. you also need a default route to the outside towards the t1 interface...
Hope this helps.. all the best. rate replies if found useful..
Raj
johnnyfranks Mon, 12/11/2006 - 18:37
thatnk you Raj, yes, the config you shared is familiar to me from a poit-to-point i worked on. i am concerned with the intra net behind the t1 which is a static ip network but private nonetheless. thank you again.
sachinraja Mon, 12/11/2006 - 20:31
cool. if u gotta private network, obviously you will do a nat/pat out the T1 connectivity.. thanks for your response.. mark the case as solved (if it solves ur query), which can be useful for others when searching.. rate replies if found useful..
RAj
