Wireless 1200 AP Authentication Failed
Answered Question
Dec 12th, 2006
I'm prett new to setting up Cisco WAP. I have tried to copy the config from a working one in another other and changed it to suit my own. I'm attaching a config. The problem is that the AP doesnt automatically get picked up by Wireless cards and when i manually set it up, i get authentication issues - DOG11-7-Auth_Failed from the station MAC-ADDRESS
Any idea? I am confused how the Vlan i have set it up on communicates. Please help?
Overall Rating: 4 (1 ratings)
rodonohu1 Wed, 12/13/2006 - 05:19
Thanks for the feedback.
I've been working on alot and built up the config again from scratch.
the problem is definatly around the authentication.
When I set it up as follows, I can't see the wireless netork:
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 key 1 size 128bit 7 3EF6C4C5A0DD03D60ACFBC40F93B transmit-key
encryption vlan 1 mode wep mandatory mic key-hash
encryption vlan 18 key 1 size 128bit 7 02DC3457EC1AAFC9DF2FAECDF0DF transmit-key
encryption vlan 18 mode wep mandatory mic key-hash
ssid EmP1R3D
vlan 18
authentication open mac-address mac_methods eap eap_methods
authentication network-eap eap_methods mac-address mac_methods
but if i put it in guest mode, then i can see the secured network but can't log on to it. When i try to connect it just times out trying. On the client, it doesn't seem to be able to exchange keys,etc. this is where I am in the dark and have difficulty figuring it out.
I've checked the ACS box and it shows on passed authentications that its fine. I just can't get up user authentication box at this point on the client.
rodonohu1 Wed, 12/13/2006 - 06:02
I've also checked this on my ACS failed attempts now: I keep getting the following that points it could be related to PEAP
EAP-TLS or PEAP authentication failed during SSL handshake
where could this issue lie?
rodonohu1 Thu, 12/14/2006 - 08:32
Excatly. I found this yesterday and it worked. The client didn't have the correct Certs so it couldn't authenticate. Cumbersome process but worked.
Thanks for your helpe Robert.
