Tim Smith Tue, 12/12/2006 - 07:11
  • Silver, 250 points or more
Hi Scott,
It's a pretty simple product to use.
If you dont have the resources internally, would suggest smartnet contract with each licence.
Or are you having a specific problem getting it installed and going?
Cheers,
Tim.
sdawson35 Tue, 12/12/2006 - 11:05
Hi Tim,
Its pretty specific..........We cannot get the "services" page to display, all we get is what looks like a load of html code. Everything else is fine. We need the services page for extension mobility purposes.
Oh and its only the Win XP Pro machines that have this problem , the others run dinosaur Win2K and they are fine.
Scott.
davidgoude Wed, 12/13/2006 - 11:29
Are you running a VPN client on all the boxes? I had an issue with a Checkpoint VPN client causing the same issue on the services page. I had to disable the VPN security policy, launch IPC, then re-enable the security policy. Once IPC had the file it needed, it was good to go, Services button and all.
