No calls outside using CCM 4.2 and mgcp gateway 2821
Any help will be apreciated.
I have a CCM with route pattern 9.XXXXXXXX, partition local,using gateway: a port ISDN PRI,and Discard Digits: Predot.
I tried with a call but it doesnt get through.
On the gateway I ran debug isdn q931 and I received:
GWY_CMSJ#
*Dec 12 20:36:22.395: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0005
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '4500'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '66336930'
*Dec 12 20:36:22.651: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8005
*Dec 12 20:36:22.675: ISDN Se0/2/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8005
Cause i = 0x859C - Invalid number format (incomplete number)
Progress Ind i = 0x8288 - In-band info or appropriate now available
I already checked the isdn codes 0x859C, I supposed need a access code to get the call through but I already configured on CCM.
THANK VERY MUCH IN ADVANCE
jbarcena Wed, 12/13/2006 - 06:32
  • Red, 2250 points or more
Your Telco is dropping the call, you need to call them and ask them what exactly they need to receive, it could be that they need 10 digits on the Calling Party Number or 10 digits on the Called Party Number, it could also be that they need to receive the Type of call as National or other setting. All of this can be configured in CCM to send the correct information but you need to ask them what exactly they need to receive.
//Jorge
gajolly Wed, 12/13/2006 - 20:52
yes, as mentioned in previous reply you need to check with telco wht exactly they are looking for because u r recieving the disconnect from telco for that you can share the same debugs with them.
