ssl vpn reconnection
Dec 13th, 2006
Hi, after the start-up phase of an ssl vpn connection to a cvpn3005 4.7.2, after the first few packets on the channel, the ssl vpn client disconnects and connects again with the following message:
"An SSL VPN reconnect resulted in different configuration settings. The SSL VPN network interface is being re-initialized. Applications utilizing the private network may need to be restart".
After the reconnection no problem arises.
Why ?
thank you
ssoberlik Tue, 12/19/2006 - 10:12
  • Bronze, 100 points or more
This is most likely an issue related with the Personal Firewall. If you disable the Firewall temporarily for testing purposes, this error should disappear.
if still errors occurs, try the following:
1- Disable the Pc Firewall.
2- Reinstall the SSL Client ( sslclient-win-1.1.0.154.zip )
3- Configuration | System | Events | Classes | Add
* SSL / WEBVPN
Events to Log 1-10
4- Restart the PC
5- enable the PC firewall.
