PIX- policy for a source
sundarr
In PIX FW is it possible to configure a policy to route the traffic from specific source to use a different gateway and rest of the network pointing to default route.
Thanks in advance
regards
R. Sundararajan
ajagadee
Sundar,
Policy Based Routing is not supported on the Pix Firewall.
Also, dont get confused when you see the "route-map" command option in Pix 6.3 and higher. This command is applicable only when redistributing routes into OSPF.
Pix 6.3 Command Reference:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/mr.htm#wp1017196
Pix 7.2 Command Reference
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/cmd_ref/qr_711.htm#wp1648744
Let me know if it helps.
Arul
** Please rate all helpful posts **
