12-14-2006 09:25 AM - edited 03-14-2019 07:13 PM
Howdy all,
I may be getting old but I seem to remember someone mentioning a software product that could analyze CM and then spit out a Visio document on the dial plan and other information for the purposes of documenting the system. Was I dreaming or does anyone remember anything of the sort?
Thanks in advance!
All replies rate
12-14-2006 09:28 AM
Check out CM Reports. www.cmreports.com
Or you can check out Variphy (www.variphy.com). Look out for Enterprise Insight, Good product to have if you are working for a VAR.
12-20-2006 05:40 AM
Thanks Shank-man!
04-29-2017 12:14 PM
Hi Travis,
I realize this thread is from a decade ago but did you find a good solution for automating the documentation of a cucm cluster?
Thanks in advance.
