EIGRP quick question on an eigrp learned route
Overall Rating: 5 (2 ratings)
pkhatri Thu, 12/14/2006 - 14:31
  • Purple, 4500 points or more
In such cases, you need to redistribute routes into EIGRP. If you just do 'redistribute connected' it will only redistrute the network for the link between A and the core router. If you have other networks connected to router A, you need to either run a routing protocol between A and the core-router OR create a bunch of static routes on the core router and redistribute them into EIGRP.
Paresh
PS> Pls do remember to rate posts
amit-singh Fri, 12/15/2006 - 09:18
  • Blue, 1500 points or more
Router C will come to know about the routes on router A, only if Core router has some static routes configured for Router A's subnet and they are reditsributed on core router.
But this will not make Router A to communicate with the router C untill and unless the Router C's subnets/networks are there in router A's routing table.This can be done either configruing static routes on Router A for the Router c's subnet or pointing a default router on Router A with the next-hop ip of core router.
HTH,Please rate if it does.
-amit singh
