VG224 low idle voltage: RMA needed?
Dec 14th, 2006
I'm having a funny issue with my VG224:
Port0 delivers something like -38VDC, same is true for other pairs (Measuring directly on Pins 1/26 that are on opposite sides of the RJ-21 connector).
However, Port 3 (Pins 3/28) delivers only -19VDC, same is true for other pairs. This is not enough for my end devices!
All Ports have the default setting of "idle-voltage high".
There seemed to be a couple bugs related to power on an IAD/VG224, but really nothing like my problem..
What are your suggestions? Ever seen something like this? RMA?
Thank you very much for your feedback
/David
PS:
The IOS is 12.4(9)T2 and my FXS chipset is as follows: "1 On-Board Twenty-Four FXS Analog Voice Module V2.1".
Rob Huffman Thu, 12/14/2006 - 16:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi David,
My vote is for RMA time. This low voltage will cause device issues as you have seen. Here is a Cisco doc that indicates what the "idle line voltage" should be. Have a look;
Ringing and Idle Voltages on Cisco FXS Interfaces
Idle Battery Voltage
Cisco voice gateways were designed for ONS connections and by default the FXS interface supplies either -24Vdc or -36dvc idle battery, whereas Off Premise Services (OPS), such as a CO, would require voltages of -48v because it may have to interconnect over much greater cable lengths.
VG224 should supply -24 Volts (low) -48 Volts (high)
From this doc;
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a008011c7f3.shtml
Hope this helps!
Rob
Michael Whaley Tue, 06/12/2007 - 10:36
Looks like this is a pretty common problem. We are having the same issue on some brand new VG224s. TAC is doing some additional research, but a few things to try:
Depending on the code version you may not have idle voltage set to high by default:
vg(config-voiceport)#idle-voltage high
You can also try manually bumping the voltage:
vg(config-voiceport)#alt-battery-feed feed2
The alt-battery-feed command in our VG bumped the idle voltage to -43VDC but still was not quite enough vs a PSTN POTS line which was giving us -45VDC.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCse92359
Mike
d.haeni Wed, 06/13/2007 - 05:40
I completely forgot to let you folks know that the RMA didn't solve the problem.
Believe it or not: the -19V Problem persisted until I downgraded the code to 12.4(4)T7 -Ouch! :)
Michael Whaley Wed, 06/13/2007 - 05:47
Our unconfigured ports show -18 to -19VDC but once they are configured as a POTS port they went to -38VDC. (We are running 12.4(13A) Mainline.
If you apply the alt-battery-feed feed2 to the voice-port you will get about -43VDC, however, TAC told us that they can not get -48VDC due to a hardware/firmware limitation. They are in the process of revising the docs on CCO.
We are experiencing an issue with multiple VG224s when attempting to raise the voltage level. Every port / gateway is working properly before applying this command. After issuing the following cmd all ports on the analog block  enter a fast busy state (lockout). Any suggestions?
