Warning message
card voice FXs
Dec 15th, 2006
I have any problem at cisco voice card FXS.., there always problem if connected to PABX line (PANASONIC)..,my temporary solution , the card FXs must be change a new card.
pls help me
thanks
spremkumar Sun, 12/17/2006 - 22:23
  • Red, 2250 points or more
Hi Abdul
FXS cards are not meant to be connected with EPABX.. E&M cards are specifically meant to be connected with EPABX boxes.
I have seen FXS cards getting faulty by doing so and also seen working with few other EPABX models..
regds
gafur1978 Thu, 12/21/2006 - 19:40
Hi Spremkumar
Tks for u solution, but first time implementation this is project the Fxs card are normal operation,but next time become trouble.., this's event has been problem again at FXs card, what the problem come from power suplay? or consumtion power PABX & FXs mismatch ?
Rgrds
spremkumar Thu, 12/21/2006 - 20:41
Hi Abdul
You may get reverse power from the EPABX and may damage your FXS port.
This is what we have heard even from CISCO but as i mentioned in my earlier post if you are sure about the EPABX port on which you are connecting the FXS port you can do that..
regds
