Warning message
**ERROR**: call_progress: DEV_CONNECTED VOICE ERROR.
Dec 17th, 2006
I keep getting this error in the debug isdn q931 but weird thing is that the call is able to connect and disconnect.
I'm facing some delay, that is, the first 2 seconds, external parties would not be able to hear the IP phone caller/callee.
Hope anyone has some comments on this.
Thanks.
Eugene
eug-c Sun, 12/17/2006 - 20:18
Oops, forgot to put the error here.
RT94TP11#
Dec 18 03:09:34.348 UTC: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8 callref = 0x00A2
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98389
Exclusive, Channel 9
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x1181, '00286512345678'
Plan:ISDN, Type:International
Called Party Number i = 0x81, '26871000'
Plan:ISDN, Type:Unknown
Dec 18 03:09:34.400 UTC: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x80A2
Dec 18 03:09:35.036 UTC: ISDN Se0/2/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x80A2
Dec 18 03:09:39.996 UTC: ISDN Se0/2/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x80A2
Dec 18 03:09:40.084 UTC: ISDN Se0/2/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00A2
Dec 18 03:09:40.084 UTC: ISDN Se0/2/0:23 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 8 call id 0x66
Dec 18 03:09:40 UTC: %ISDN-6-CONNECT: Interface Serial0/2/0:8 is now connected to 00286512345678 N/A
eug-c Tue, 01/09/2007 - 21:40
Hi hi,
Anyone has encountered this before?
Thanks.
Eugene
jbarcena Wed, 01/10/2007 - 06:22
  • Red, 2250 points or more
- What is type of GW are you using? MGCP or H.323?
- What is the model of the GW?
- What IOS are you using?
Take a look to this bug:
CSCse55246: Unnecessary message printed**ERROR**: call_progress: DEV_CONNECTED VOICE
Symptom:
An unnecessary error message is thrown after the call is connected.
*May 22 22:38:33.691: ISDN Se1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x8001
*May 22 22:38:33.703: ISDN Se1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
*May 22 22:38:33.703: ISDN Se1/0:23 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 0 call id 0x1
Conditions:
After the call is connected .The Error message is thrown .
Workaround:
None
Upgrading the IOS normally fix the problem (if you are on a version that hits this bug)
//Jorge
etmarcof Fri, 03/02/2007 - 08:57
I'm having same error with cisco 2821 H.323 GW( IOS 12.4.11T.) with CCM 5.04 Did you solve problem?
Could this error be related with initial 2 seconds delay?
BR
MC
