CCM with 2751 connected to Avaya G3 problem
Dec 18th, 2006
  • Green, 3000 points or more
I have CM 4.1.3
2751 voice gateway
Avaya G3 Release 8
We have the two systems connected, dialing back and forth, but we have some issues with CCM pushing digits too fast to the Avaya G3... sounds odd, but we have something is not correct.
Hitting the PBX, getting invalid number... any tips on this?
Thanks!
sgossen Wed, 12/20/2006 - 08:53
What type of connection do you have between the two? PRI? CAS/wink?
-Go0se
Tommer Catlin Wed, 12/20/2006 - 12:49
It was PRI, but we figured out that the CCM gateway was sending some mis configured ISDN information to the Avaya and freaking the Avaya out. Once we cleaned it up, it was fine.
