Site-to-Site VPN Configuration
spremkumar Tue, 12/19/2006 - 01:25
  • Red, 2250 points or more
Do make sure that you have the required IOS code files to have IPSEC tunnels configured in your routers.
In case if you need to upgrade the ios code then you need to check out for the required flash/memory in your routers.
You can refer 'IPSec on Router to Router' section on the below link.
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
You can refer the below link for the required ios in your router..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
roluce Tue, 12/19/2006 - 10:37
Personally, I'd start with DMVPN.
http://www.cisco.com/en/US/products/ps6658/products_ios_protocol_option_home.html
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455c71.html
It's more flexible, and can be easier to manage for IOS to IOS secured networking. Pure IPSec VPN's are more common, but can be a bit steep of a learning curve, particularly in troubleshooting connectivity issues.
Both versions of code that you have support DMVPN, but I'd recomend upgrading your code to the latest for any secured VPN solution.
Rob
