Choosing a Router
Dec 19th, 2006
Hello
I need some help in choosing a router and the cards for expansion that i should ask. Basicly what I need is that the Router must have 3 Ethernet Interfaces. It mus t have ability for multiple VPN connection from other devices and also from Cisco VPN client. and also must have an IOS that offers good securitty.
Any sugesstions please.
spremkumar Tue, 12/19/2006 - 03:37
  • Red, 2250 points or more
do throw more on the kinda connectivity you are going to have on this box to get you connected to the outside world..
You also need to check out the number of vpn tunnels you need to support using this box..
regds
KlediBodinaku24 Tue, 12/19/2006 - 07:36
THis Router Would have probably the need to use up to 500 VPN connection. It wont connect directly to the outside world, but will have connection with 2 routers and 1 PIX and will serve as a bridge between these two routers and the PIX. I was thinking something like 2811 or 2821 but I would like some help of chosing what kind of other cards do i need to request with it and what kind of IOS should i use.
spremkumar Tue, 12/19/2006 - 21:48
You can refer the attached doc for the required info on selecting the suitable hardware for you.
Also do keep in mind about the future expansion before selecting a hardware now..
regds
