Warning message
Slow access to local resources with Cisco VPN 4.0.2
Dec 19th, 2006
I am experiencing an extremely slow access to local resources when connected to VPN.
Sometimes it takes more than 10 seconds to open a folder in windows explorer.
I have the same problem in 2 different machines, my desktop and laptop.
I am using Cisco VPN client 4.0.2 with Windows XP SP2.
I tried the options 'enable transparent tunneling' and 'Allow local LAN access' with no success.
Does somebody have a clue on what the problem can be?
Thanks.
bwalchez Tue, 12/26/2006 - 08:05
Try by upgrading the Cisco VPN client to 4.8 and see.
jeroenvanassche Wed, 03/26/2008 - 10:00
I don't know if any of you came up with an answer to this problem, because I have the exact same problem.
I use version 5.0.01.0600 of the VPN Client. Windows Explorer hangs for a couple of seconds and then works fine for a couple of seconds and then hangs for a couple of seconds, etc. When logged on in Windows XP with a user with administrator rights this problem doesn't occur. Only when logged on with a Restricted user (Users Group) does this problem occur.
Hoping you can help,
Jeroen
