Migrate from PIX 501 to ASA 5505
Dec 19th, 2006
I need to migrate from a Cisco PIX 501 running 6.3(5) and to a Cisco ASA 5505 with 7.2(1).
The 501 is setup for several VPNs, all 3DES.
I need to get the 5505 up as quickly as possible, can the config from the 501 be used?
What do I need to look out for?
spremkumar Tue, 12/19/2006 - 22:14
  • Red, 2250 points or more
The cli is very much similar with some difference here and there in ASA mostly with the interface mode config..
You can refer the cli of both ASA OS version to make sure you are inline with the CLI..
regds
