Warning message
VRF-Lite with Backup ISDN
Dec 19th, 2006
Dear All...
I need to build a project with VRF-Lite and Backup ISDN. In my lab, VRF-Lite is perfect, but now, I need to configure a backup of Dedicated Link through ISDN Link, Dialer Interface.
So I would like to get an help to build this project. What does best way to configure a Backup link with VRF-LITE? and the routing table needs to keep separated, if possible.
Topology is attached.
CLRGomes
cassio.gomes Sat, 12/23/2006 - 17:26
Dear All...
I made a lab with a solution in my mind and it works very well.Now I need to do a new tests with much devices.
But, the summary is, I used a router CE as PE the same time, very crazy, but it works.
If anyone would like to know more and discuss about this solution I will apreciate.
CLRGomes
