Maximum console cable distance between PC & Router/Switch
Dec 20th, 2006
  • Silver, 250 points or more
What is maximum console cable distance between a Router/Switch & PC if i make it manually? bcoz in my remote center there is no laptop with the engineer, so when ever he wanted to check the router/switch via console he need 2 shift the pc near the router/switch, so instead i told him 2 make it manually done & it works fine, but i also wanted to know what is the limited allowed distance.
Overall Rating: 3.3 (4 ratings)
mtechnology Wed, 12/20/2006 - 01:41
Hi Anand,
What i generally do in these scenarios is that i connect the console serial port to any RJ-45 jack (used for ur n/w connectivity near ur PC) and extend it to the switch/router console with the existing cat cable.
And i have used it successfully over 60 meters
Narayan
Anand Narayana Wed, 12/20/2006 - 05:43
Thanks Narayan & Andrew, it was usefull & also i can share this info to others.
