Warning message
network.king Wed, 12/20/2006 - 02:59
  • Silver, 250 points or more
Hi ,
IF you are using VOIP in a single LAN with a single switch then , a seperate VLAN would be fine . But if you have a good switch network with data also eating up lot of bandwidth , then it would be better to do some priority queues for Voice traffic.
Hope this helps
regards
vanesh k
jasoking Thu, 12/21/2006 - 06:24
what was the problem you had with your voice traffic?
