Warning message
Layer
Dec 21st, 2006
You have just set up a new workstation on your network. You successfully PING your loopback address and a server on your same subnet. On trying to PING a server on another subnet, you receive the message ?Destination host unreachable?.
Where in the OSI model did the error occur?
sourabhagarwal Thu, 12/21/2006 - 05:14
  • Gold, 750 points or more
Layer 3 Network Layer problem. Inter-vlan routing has to work to route packets between different subnets. either inter-vlan routing is not working or Layer 3 device doesn't have destination network in its routing table.
rate if it helps ....
