Warning message
Reporting Tool for Switch Configs
Dec 21st, 2006
All,
does anyone have a good reporting tool that can search through my configs and highlight errors within the config or highlight sections based on a Find?
I have a switch config with hundreds of ports that if certain criteria are met, that port is highlighted. Any help is appreciated.
Anand Narayana Thu, 12/21/2006 - 22:31
  • Silver, 250 points or more
according to my knowledge, there is no such tool to highlight the errors on the configuration which you will paste of ur switches/routers.
senglobe0907 Thu, 12/21/2006 - 22:48
you can use cisco works... which will show you section based config or through find option.
Rgds
Senthil
