6513 modules not detected ( urgent )
Answered Question
Dec 22nd, 2006
Dear all
I have cisco 6513 switch ( IOS Version 12.2(17d)SXB9 ).i have one ethernet modules installed . i can see this module from CatOS , but i am unable to see ethernet module when i login into MSFC
Router#sh version
IOS (tm) MSFC2A Software (C6MSFC2A-JK9SV-M), Version 12.2(17d)SXB9, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 21-Jul-05 03:42 by pwade
Image text-base: 0x40008FBC, data-base: 0x425D8000
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: MSFC2A Software (C6MSFC2A-JK9SV-M), Version 12.2(17d)SXB9, RELEASE SOFTWARE (fc2)
Router uptime is 1 minute
System image file is "bootflash:c6msfc2a-jk9sv-mz.122-17d.SXB9.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco MSFC2A (R7000) processor (revision MSFC2A) with 458752K/65536K bytes of memory.
Processor board ID MSFC2A
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
509K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
show version , sh run-config unable to show any ethernet module , nor i can see any interface commands related to gigbitethernet
how i can deletect ethernet module in MSFC .
Correct Answer by ankbhasi about 10 years 8 months ago
Hi Kernel,
Yes you can run your switch in NATIVE IOS mode but currently your switch is running in Hybrid mode and to convert form Hybrid mode to Native mode you have to go through the conversion procedure.
Have a look at this link for more details on Hrbrid mode to Native Mode conversion
http://www.cisco.com/warp/public/473/81.html#conv_msfc_2
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (1 ratings)
ankbhasi Fri, 12/22/2006 - 12:10
  • Cisco Employee,
Hi Kernel,
You are not running a Native IOS on your box and your sup engine is running in HYBRID MODE where there is a CATOS for all layer 2 configuration and interfaces configuration and IOS loaded on MSFC for all routing configuration.
In HYBRID mode you can see all modules only from CATOS and when you access MSFC via session command you are on the IOS on MSFC which can be used to configure all layer 3 coniguration like intervlan routing and other stuffs.
Only when you are running a NATIVE IOS which means a complete one IOS for both supervisor and msfc then from IOS mode you can see all your modules installed and can configure the ethernet interfaces even as layer 3 interfaces which is not possible in HYBRID mode.
So you won;t be able to see any modules from MSFC itself. So you can configure your ethernet module and its interfaces only for layer 2 operation from CATOS and all configurations relating to layer 3 for those vlans should be done on MSFC.
Ankur
*Pls rate helpfull post
kernel_2431 Fri, 12/22/2006 - 12:28
Thanks a lot for your reply
Can i run the my switch into native IOS mode
K
Correct Answer
ankbhasi Fri, 12/22/2006 - 12:35
  • Cisco Employee,
Hi Kernel,
Ankur
