Warning message
Removing SNMP Trap Host
Dec 23rd, 2006
I am trying to remove a snmp trap host from the "show snmp" output. It is not there in the running configuration. But it shows in the "show snmp" output. Is it a bug? IOS is 12.2(18)SXF5. Platform is 7600.
DOH-7600#sh snmp
Chassis: FOX083306Y6
82231822 SNMP packets input
0 Bad SNMP version errors
691933 Unknown community name
26628956 Illegal operation for community name supplied
1 Encoding errors
195725215 Number of requested variables
453450 Number of altered variables
9094626 Get-request PDUs
44926578 Get-next PDUs
27441106 Set-request PDUs
83451021 SNMP packets output
0 Too big errors (Maximum packet size 1500)
28322753 No such name errors
285011 Bad values errors
285021 General errors
81539758 Response PDUs
1911134 Trap PDUs
SNMP global trap: disabled
SNMP logging: enabled
Logging to 172.28.1.66.162, 1/10, 1391240 sent, 287192 dropped.
Logging to 172.28.1.67.162, 0/10, 0 sent, 0 dropped.
Running configuration has only the following host configured.
snmp-server trap-source Loopback0
snmp-server host 172.28.1.67 public
Prakash
Overall Rating: 3.5 (2 ratings)
Martin Ermel Thu, 12/28/2006 - 07:45
  • Blue, 1500 points or more
Just a quick idea,
try to remove ANY trap host from the config and verify the entries with "sh snmp"
if that still does not help remove the complete snmp config. This should reset the snmp agent. Now you should be able to readd the config you want.
Joe Clarke Thu, 12/28/2006 - 09:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The problem with the lingering trap host is most likely due to the fact that there is a still a notification wedged in the output queue. Unfortunately, you will have to reboot to clear this problem.
prakashj Sat, 12/30/2006 - 23:44
Thanks...I think may have to reboot the router...just wondering whether its an IOS bug?
Prakash
Joe Clarke Mon, 01/01/2007 - 09:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This does sound like it would be a bug, but I could not find an existing one that describes this behavior.
