transferring ios image from 6500A to 6500B
Dec 27th, 2006
I have to transfer (copy) an ios image from Cisco 6500 A to 6500 B. 6500 B hasn't is empty, no ios on board.
I'd like to know what procedure follow step by step in order to transfer the ios file from A to B using a PC that has both consolle cable and network connection
ankbhasi Wed, 12/27/2006 - 08:30
  • Cisco Employee,
Hi Friend,
As you mentioned "6500 B hasn't is empty, no ios on board" Can you please confirm if it has no image then by whch image it's been booted from? Is it currently in rommon mode?
Confirm the status of switch B and will post you with a probable solution.
Ankur
ogadri Wed, 12/27/2006 - 08:49
Hi Ankur,
you are right.
In effect 6500 B is in the state as when you turn it on the first time ...I hope it can be useful.
thanks a lot
Simone
ankbhasi Wed, 12/27/2006 - 08:54
  • Cisco Employee,
Hi Simone,
When you turn it on for the first time it will definetely has some image onboard and that image will be a CATOS where only setbase command works. Can you check with "dir bootflash:"
Also can you paste me the output of "sh version" if possible from 6509 A & 6509B.
Also if it is running CATOS can you confirm which mode CAT6509 A is running?
Ankur
ogadri Fri, 12/29/2006 - 02:57
I'm going to provide you the show ver about 6500 in few days, now i'm not near the devices.
Another thing i have to solve is the same scenario but with 3560 IOS EMI (3560 A is running 3560 B is just turned on). This last is more urgent than 6500. Is it easy with this info for you to solve my problem?
Thanks a lot,
simone
ankbhasi Fri, 12/29/2006 - 05:12
  • Cisco Employee,
Hi Simone,
Yes for 3560 both runs IOS images so what you can do is copy the image from one 3560 on your tftp server and then copy back the same image from tftp server to another 3560 switch.
Now first you have to download a tftp server on your machine and get the machine connectivity to your first 3560 switch and then tun this command
copy flash: tftp://ip address of machine/imagename
and doing this image will be tranferred from your first 3560 switch on your machine where you have tftp server.
Noe because you have a new 3560 switch it will not be hvaing any ip adress so console into the 3560 switch and assign one ip adress on interface vlan 1 and once done connect the same mcahine on which you have tftp server back to new switch and run the command
copy tftp://ip address of machine/imagename flash:
and this will transfer the image from your tftp server back to the new switch flash and once done set the boot path on new switch with the new image name
boot system flash
wr mem
reload
and your new switch will boot with the same image which you have on your existing 3560 switch.
Ankur
*Pls rate helpfull post
