Warning message
Cisco 6513 Cat OS to Native IOS Upgradation
Jan 2nd, 2007
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
We have 3 Cat6513s with dual Sup-II, running on Hybrid Mode, would like to know the steps to upgrade the Hybrid into Native IOS.
Kind Regards,
Wilson Samuel
Overall Rating: 4 (1 ratings)
ankbhasi Tue, 01/02/2007 - 08:17
  • Cisco Employee,
Hi Wilson,
Since its a conversion from Hybrid Mode to Native Mode it needs a downtime and it need to be done one by one on both the sups in single chassis.
So the best way will be to arrange some donwtime and take out the standby sup from the chassis and first convert one sup from CATOS to Native IOS and once done take that out and insert the second sup and perform the same steps for conversion.
Have a look at this link which has step by step instructions for conversion from CATOS to Native IOS.
http://www.cisco.com/warp/public/473/81.html#bootintegratedios
Ankur
*Pls rate helpfull post
Wilson Samuel Tue, 01/02/2007 - 08:29
Thanks a lot Ankur, I will go through the link and will get back to the forum in case required.
Kind Regards,
Wilson Samuel
