Multiple Vlans and DHCP..
Jan 2nd, 2007
Good Afternoon All.
I have several remote sites connected back to the main office via IPSEC VPN (netscreen) At some of these remote sites we have a Cisco 1130AG deployed for ethernet connectivity. A netscreen is put into DHCP-relay mode and points back to a central Win2k3 DHCP server at the main office to provide IP's for staff. Now, i want to introduce a guest-vlan on the AP with a different scope -- how can i accomplish this ?
i wanted to create a separate dhcp-pool for the guest ssid/vlan on the autonomous AP (no controller network) and configure the port on the switch it connects to as a trunk-port(3com switch) And make everything local.
I still want staff to receive IP's from the DHCP server at the main office.
any insight on the commands or principles would be very helpful.
Stephen Rodriguez Wed, 01/03/2007 - 11:52
  • Purple, 4500 points or more
Harry,
This can be done, and is fairly simple. What you need to do is, on the Subnets gateway, point that interface to the AP using the ip helper-address command. This tells the gateway to encapsulate the broadcast DHCP request and points it at the correct DHCP server. The AP will reply with address from the configured scope.
phipps_1t Wed, 01/03/2007 - 14:14
Steprodr.
If i wanted to use one central DHCP server, can this still be done ?
In my setup, the netscreen is acting as a DHCP-relay and can't act as a DHCP server. In other words, it's exclusively a dhcp relay-agent to get IP's from the scope defined on the central DHCP server.
i'm kinda fuzzy on your response..to clear up the proposed deployment, lets say i wanted to use one DHCP server only which is located at the central office --- how could i do this ?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
